WMC2003 error in using VZ Manager on 4G with UML290 USB card
broadwayuser007
Hi all,
I am using VZ Manager 7.6.3.1.      Pantech USB card  UML290VW
I am in the middle of Manhattan.  Great coverage.  I have trouble using the software to connect.  Our of ten attempts, it works twice.  It reports "device could not establish a connection" and reports WMC2116 and WMC 2003 and WMC 2002 error codes.  Do you know what these codes mean?
I am a professional programmer; unfortunately, this software does not seem to have gone through a rigorous QA cycle.
I used to have the 3G card, and it was lot better than the 4G card.
Can you help?
Thanks.
Re: WMC2003 error in using VZ Manager on 4G with UML290 USB card
bridgewater
i am having the same problem.  it's particularly bad and bothersome from my nyc office but i also get the message from time to time at home in nj or on my commute.
how long does it typically take for someone from verizon wireless to reply to these boards?  this is my first post.
Neander
Novice
Have you two checked the posting below from Zoso20?
