Battery Charger Only Charging Cellphone Lithium Ion Batteries up to 85%
f_canton
Why is my battery charger only charging my cellphone lithium ion batteries up to 85% and not 100%.  When inserting the battery back into the phone after charging and turning it back on, the phone only shows 85% instead of 100% near the battery icon on the status bar.  How is this problem going to be fixed?  Is this the way cellphone lithium ion batteries are set up for chargers which is by only charging them up to 85% and not 100%?
Re: Battery Charger Only Charging Cellphone Lithium Ion Batteries up to 85%
f_canton
Maybe the reason why it is charging up to 85% instead of 100% is because of memory effect.
