No audio when using headphones.
LuJoa
Has anyone had issues when using headphones with the android maxx?
Correct Answers
Re: No audio when using headphones.
Snn5
Sr. Leader
I have seen other reports here involving the Motorola Droid MAXX regarding the headphone port.  Usually it's either a case that obstructs full insertion of the jack, debris in the port, or faulty headphones.
Salisbury
Sr. Member
On every devices iPod etc. Usually it's the head phones and not the device it self. Try swapping them out. Wow after participating in Apple support forums for years. I have to feel bad for how bad Verizon is trashed! They, Verizon are a great carrier and the post I read are ridiculous! Verizon likely replaces more devices, simply because people don't understand the hardware or software.
Snn5
Sr. Leader
