Phone case and wireless charger?
Hecate115
I have a Samsung Galaxy S7 edge with an Otterbox case. Will a wireless charger work with the case on or would I need to remove it? For example if you were using the Verizon Qi Wireless Charging Stand - Verizon Wireless or Samsung Fast Charge Wireless Charging Stand - Verizon Wireless
Thanks!
Re: Phone case and wireless charger?
Spiral
Sr. Member
Both of my wireless chargers work perfectly with my Samsung Galaxy S7 in it's Otterbox Commuter case.  My chargers are not the same as yours but I don't see why there would be any difference.
Good luck
Tidbits
Sr. Leader
Depends on the material and how thick they are. Friends have cases that don't work.
