What's the best full body screen protector for the s6 edge?
momv630
I just waited 45 mins. at the Verizon store for help. Finally got a salesperson, only for them to tell me they are out of screen protectors. I need something that will allow me to use android pay. Android pay doesn't work with a case. Thanks.
Re: What's the best full body screen protector for the s6 edge?
rcschnoor
Sr. Leader
Sr. Leader
Are you looking for a case or a screen protector.
Android pay DOES work with cases. I have used it many times with one. Some cases may be a bit too bulky to allow it, though.
momv630
Well I initially wanted just a screen protector but the Verizon store guy said Android pay won't work with a case. So then I though full body glass protector? Any advice?
rcschnoor
Sr. Leader
Sr. Leader
There is no such thing as a "full body" glass protector.
Personally I don't use a case or a screen protector anymore, however I have used the following case on other phones successfully with Android Pay.
http://www.verizonwireless.com/accessories/shell-holster-combo-with-kickstand-for-samsung-galaxy-s-6...
However I have never used the portion which covers the face of the device, only the portion which covers the back of the device.
momv630
Thanks, but I think I need maybe a glass protector. Idk, why my phone won't work for Android pay. Will have to try it at different locations.
