Curious if anyone has ran into or knows of a fix for this issue. My data use was higher than normal on my bill and it indicated from audio use. Then noticed when I stream video or audio using my Bluetooth headset it drops my WiFi connection. This just started to happen was hoping someone had a fix. Thanks
Keeping your data usage under control is definitely important so I completely understand your concern Skol. Let's get to the bottom of this and help manage your data usage.
Where did you see that the data usage was from audio? What phone do you have? Is the WiFi connection being losted completely when connected to your Bluetooth?
JohnB_VZW
