4G LTE router w/voice external antenna - what size connection and how far can it be run from the router?
striker308
I have the 4G LTE router with Voice in my house, the absolute best signal we can get inside the house and within 50 yards of the house outside is 103dbl
what size connection does the router use for the external antenna jack and whats the max distance you can run an external antenna?
Tags (1)
Correct Answers
Re: 4G LTE router w/voice external antenna - what size connection and how far can it be run from the router?
John_Getzke
Leader
Leader
Specs on the connectors can be found here:
http://www.alternativewireless.com/machine-to-machine/hotspots/novatel-t1114-router-signal-boosters....
"CABLE: When selecting cable, match up connectors to the router (SMA) and the antenna (FME or N Type). The use of the screw on adapters "SMA Male/FME Male Adapter 971119" or "SMA Male / N Female Adapter" see product listing below) may be required."
John_Getzke
Leader
Leader
