Add a phone currently with Straight Talk to my Verizon plan
JeanMB222
What's the easiest way to add a phone currently with Straight Talk to My Verizon plan?
Re: Add a phone currently with Straight Talk to my Verizon plan
Ann154
MVP MVP
MVP
You have to add a line and port the number from Straight Talk. You might have to purchase a compatible phone if the you don't have one.
Snn5
Sr. Leader
Are you wanting to bring an extra/new line to Verizon or just the phone?  The phone may not be compatible even though ST uses Verizon towers, if the phone is a GSM and your phone used the ATT towers.  Otherwise, if it is just the number, you just go through the shopping process online and port your number in, or do the same in-store.
