Currently I have DirecTV Genie set up hooked to my ATT DSL Landline. All works well. Can I hook up my DirecTV system to Verizon's LTE Internet and home phone device?
JOHBEN72, let's get the clarification that is needed about your unlimited data options. https://www.verizonwireless.com/support/new-verizon-plan-unlimited-faqs/ Please note item #1 under "General Information".
On the new Verizon Plan Unlimited you get our fast LTE speeds. To ensure a quality experience for all customers, after 22 GB of data usage on a line during any billing cycle we may prioritize usage behind other customers during network congestion. This means your data connection could slow down.
*Mobile hotspot/tethering reduced to 3G speeds after 10 GB/month per line
Does this help? Is there anything else that we can help clarify?
JoelR_VZW
Nope! Verizon Wireless Home Phone doesn't do telephone modems.
JOHBEN72, I imagine you are referring to this here LTE Internet and Home Phone ( https://www.verizonwireless.com/home-office-solutions/verizon-lte-internet-and-home-phone/ ). If that’s the case then and as long as your DirecTV system has wi-fi capabilities, then connecting the two using wi-fi is the same as connect any other wi-fi device. What plan do you have with Verizon Wireless? Is it the new Verizon Plan Unlimited?
DavidH_VZW
Thanks for the responding. My DTV Genie system is currently Ethernet hardwired to my NetGear DSL modem/router. This allows streaming content (if so chosen) and apps to be available on DirecTV. My assumption is that I can do the same with the Verizon LTE Internet and Home Phone. device
I am replacing my ATT DSL service (finally!!) with Verizon's Internet home phone - Internet device on the unlimited plan. Only issue its on backorder until next month.
Again thanks for your response.
JOHBEN72, we don't want you to have inaccurate information. I'm here to clarify things for you. The unlimited plan only covers your home device for up to 10GB of 4G LTE data. After that it will be slowed to 3G speeds. Unlimited is only available to smartphones and tablets.
Does that help you out?
MarcusS_VZW
No.
My understanding at sign up of the unlimited plan was that there was the possibility of my speeds being reduced if I exceeded 22 GB of data in any given billing period. There was no mention of which device I used. Which would be ridiculous. Could you clarify?
Thanks
JoelR_VZW
Thanks. Clarified.
Nick [Removed]
personal information removed as required by the Verizon Wireless Terms of Service
Message edited by Verizon Moderator
