Help!
foreveratiger
Just purchased the Jetpack but am having issues getting it connected so that my Direct TV runs off its WiFi.  Is this supposed to be compatible with it?
Correct Answers
Re: Help!
foreveratiger,
Let's make sure you are all set up with your new device. The device should have no troubles connecting with your wireless devices. However, please know that using this device to stream media from your cable provider would use quite a bit of data as media streaming would be very data intensive. Are you receiving any specific errors when attempting to connect or what seems to be giving you some trouble?
AdamG_VZW
Re: Help!
foreveratiger,
AdamG_VZW
