Intermittent VPN (PPTP) connectivity using Ellipsis Jetpack 4G LTE
bagman011
I'm having and issue with a very basic PPTP (Win 7 Network Adapter) connection over an Ellipsis Jetpack 4G LTE w/VPN Passthrough enabled, to a Watchguard XTM2 Device.  It will connect, but then, almost at random it won't allow a connection over PPTP or IPSec.
  • The user can connect via his phone (via Verizon Mobile Hotspot) and home WiFi with no issues, but only randomly from the Jetpack.
  • We have tested the VPN via PPTP and IPSec from a variety of devices running Win7 and 10... we know it works.
Is there a client setting or server side setting we can use?  I think we've isolated the issue to the Jetpack... now we would like to know if there's a workaround.
Thanks!
Correct Answers
Re: Intermittent VPN (PPTP) connectivity using Ellipsis Jetpack 4G LTE
bagman011
OK... I went in and enabled port filtering (it was turned off) and set the following Custom Applications:
PPTP 1723 TCP
L2TP 500 UDP
L2TP 5500 UDP
L2TP 1701 UDP
RDP 3389 TCP
RDP 3389 UDP
The PPTP and IPSec VPNs are connecting... for now.  The worst thing about this is that it's an intermittent issue with the customer.  I'm going to have them test it out and get back to us.
Thanks for the replies everybody.
bagman011,
Thanks for getting in touch with us on the forums. Sorry to hear about the trouble with the device. Let's see if we can get it working. I know how important staying connected is. Was it working at some point and then stopped, or is this a new setup for the user? Have you tried hard resetting the device already?
EricW_VZW
7e18n1
Sr. Member
Try this, login to the Jetpack’s web interface, disable IPv6 (see page 33 in the User Guide) and restart the Jetpack.
bagman011
Hmm... no, I don't think we've disabled IPv6.  I'll connect over and un-check the box.  Can't hurt to try.
Thanks!
bagman011
Hi EricW_VZW,
This device (Jetpack) has always had intermittent problems with the VPN, the normal internet/HTTP connection is fine.  It has been hard reset at least twice and it's about a year old.
Thank you for these details, bagman011. We all know how important it is to stay connected, the steps performed up to now are pointing towards a compatibility issue between the device and the VPN. Let’s be sure to leave no stone unturned.  We’d like to verify that the Jetpack is up-to-date with the latest firmware.  Here is how to check for and complete one if needed: http://spr.ly/6588BMUOk
DavidH_VZW
bagman011
Hi DavidH_VZW,
We're up to date:
System software version
R700G.VZ.26.1008
Firmware version
0.1.2.50
bagman011
OK.. I just checked and IPv6 is off.
bagman011
PPTP 1723 TCP
L2TP 500 UDP
L2TP 5500 UDP
L2TP 1701 UDP
RDP 3389 TCP
RDP 3389 UDP
Re: Re: Intermittent VPN (PPTP) connectivity using Ellipsis Jetpack 4G LTE
7e18n1
Sr. Member
Does Jetpack > About show this Jetpack has a reserved IP address?
Are you trying to use Remote Desktop to access a computer connected to the Jetpack?
