Pantech UML 290 VZ Modem does not auto connect.
jon_frederick
Working with Windows 8.1 and using a Pantech USB Verizon 4G LTE Modem as a Windows Broadband device on a mobile asset, and when signal is very low for a period of time the modem will "disconnect" from the VZ network and will not auto connect once the signal gets stronger.
The end users are finding this to be inconvenient for them that the modem doesn't auto connect. I'd rather have them keep their eyes on the road then checking the connection. When the end users go into the Verizon connection in the Windows wireless connection list the option for "connect automatically" is selected including the option for "roam automatically".
This happens in 3G and 4G modes; NOTE that the modem in the end gets set to 3G.
I have researched this on the Verizon site and the internet for answers to remedy this, at this time without success.
Is there a setting that I might be over looking that will cause the connection to keep trying until it connects?
Does anyone have any ideas, suggestion?
Jon
Re: Pantech UML 290 VZ Modem does not auto connect.
Hi jon.frederick!
Thanks for the details, let's look into the auto connect fuctionality. Your previous efforts are greatly appreciated. What is the current software version:http://www.verizonwireless.com/support/knowledge-base-56486/ ?
AyaniB_VZW
jon_frederick
I apologize for not mentioning (thought I did) we are just allowing Windows to manage the connection since Windows 8.1 Pro has this capability.
jon_frederick
The Pantech driver is 4.14.8 that is being used as well.
