Personal hotspot ability with Verizon Max plan
keener1018
This past April, I had to give up my unlimited data and was given the Verizon Max 6 GB plan. Now I would like to be able to use the personal hotspot on my iPhone but am told I have to change plans to the More Everything Plan which is at least $20/month more. I'd only like to use the personal hotspot on occassion so I do not want to change plans. Does anyone know if I can keep my current plan and be able to use the personal hotspot?
Correct Answers
Re: Personal hotspot ability with Verizon Max plan
elliew
Sr. Member
It is also an additional $20 to move to the higher Verizon Max plan w/ 8GB that includes the mobile hotspot.
You can move between these 2 plans (6GB and 8GB w/MHS) as needed. Move for the month and then move back to the lower Max 6GB plan.
elliew
Sr. Member
