Poor reception on Verizon Wireless Home Phone Model F256VWQB
PlanetX
Recently been getting extremely poor reception on Verizon Wireless Home Phone Model F256VWQB which I purchased 5 years ago for my Dad. Looking for trouble-shooting tips for this unit which is of course just a box that took the place of his landline system. There is no Wi-Fi where this box is located so an extender is not an option. Wondering if a newer replacement model would fix this issue but not sure if it would.
Re: Poor reception on Verizon Wireless Home Phone Model F256VWQB
Hello, PlanetX. Help is here. We want to make sure your home phone is working as it should. To clarify, is it a 3G device? CourtneyM_VZW
Tena49
I am replying here because I am having trouble with my wireless home phone as well. Nothing on the box indicates the model number or manufacturer. Mine probably is 3G. Is there a later model for an upgrade?
Thanks for your reply, Tena49. I would like to check the software version. Please click this link, follow the steps, and let me know if you have different results: http://spr.ly/6607JZegW; -Jordan
