Printer
Virdean
My Cannon MX472 connect wireless to my computer and Modem
Re: Printer
Virdean
why?
Re: Printer
Ann154
Expert
Expert
Why what? Why can it...? Why can't it...? Please describe the issue with structured sentences and paragraphs.
Re: Printer
John_Getzke
Leader
Leader
What does this have to do with Verizon?  You might have to check with the User Guide of your printer or Cannons support website to review the possible connections that your printer can support.
Based on what you have described so far, which isn't very much, I would assume this is a wireless connection problem between either your printer and the computer or the printer and your home router.  Review the printers wireless connection options and try to reconnect it with the correct WiFi credentials.
If you want more specific steps then please provide us with more details on what it is you are trying to do or need help with.
