Range Extender Problems
Lorenb69
My range extender ceased functioning. Top and bottom lights are solid blue. The middle lights are slow flashing red. My phone says there is no mobile service available. I have restarted it 3 times and it still doesn't work. I called Verizon and was told that a representative would call me on my landline. No call yet. Maybe they aren't working either. Does anyone have any ideas? I am in a marginal reception area and have no cell signal.
Re: Range Extender Problems
Lorenb69,
I know how important it is to stay connected. After all, we use our phones for everything these days. Let's make sure we get your extender up and running. How long has this been going on? Are you having any troubles with your home internet? Is the extender connected to your home router? Have you also attempted to reset your home internet? Are you utlizing the GPS antenna that came with the device and would it be in a open location for signal?
AdamG_VZW
Lorenb69
Adam,
This happened yesterday after working OK for about a year in it’s present position.
Internet is working fine. Modem has been restarted twice. Range Extender has been
restarted 5 or 6 times. I am not sure where the GPS antenna is as there is nothing
labeled as such. The Range Extender is sitting about 12 inches from a window and is
connected to the router. I have no cellular service at this time not even outside in my
yard. Paying Verizon $185 a month for marginal service is ridiculous. I wonder if another
company could give me better service?
Loren
Lorenb69, getting your Network Extender up and running is a must. We would never want, you are our priority. Allow the opportunity to resolve the issue. Restarting the device is a great route to start but what is also important is restarting the high speed interent as well as it drives the usage. Have you tried this step? Also, when you do power cycle the Network Extender, you should allow a full hour to ensure the connection is solid.
NatashaA_VZW
