T2000 wireless home phone
rrbrown7
Has anyone had any success faxing using the T2000 for connectivity? My HP8620 all in one won’t send or receive despite being group 3 compliant as specified in Verizon support. Settings adjusted as shown on:
https://www.verizonwireless.com/support/knowledge-base-212440/
Re: T2000 wireless home phone
rrbrown7
Spent more or less of an entire day on Facebook messenger with Verizon support. Try this. Try that. Reboot this. Try again. Rinse & repeat. No one can tell me if anyone has been able to fax using the T2000. No list of supported fax devices. Did Verizon bench test to confirm this feature actually works? Just crickets when I asked that question. The marketing material clearly says supports group 3 fax machines.  Everyone? Which one? Not the ones I have from hp or Epson. And now ...  wait for it .... it has been suggested that I PAY for  Verizon tech coach to resolve the T2000 support of fax.
Works good for home phone. Absolutely terrible at the promised fax capability.
