USB Modem U620L does not autoconnect after a soft reboot.
brank27
I have configured USB Modem U620L to automatically connect to the internet, but after windows initiates a reboot the U620L will not automatically reconnect.  The U620L does automatically connect when I physically disconnect it or completely power cycle the PC.  This is a remote PC so I will not have physical access to the hardware and it is critical that the modem automatically reconnect after a soft reboot.
Tags (1)
Re: USB Modem U620L does not autoconnect after a soft reboot.
7e18n1
Sr. Member
What Windows and VZAM versions?
