When battery is fully charged on MiFi6620L, screen says connect power. User guide does not indicate this is necessary. Which is the better way. We always use the MiFi where we have power available.
Alan.Brandt,
It's great to hear it's working just fine both plugged in and unplugged. Whichever option is most convenient for you will work fine with this device. Neither way will harm the device or the battery.
SarahO_VZW
Alan.Brandt,
When it comes to MiFi I would say that it would be best to do whichever you want. Some of the times keeping it plugged in is fine, while other times it isn't necessary. Are you unable to connect if the device is unplugged from the power source?
ErinW_VZW
Thank you for the response. The MiFi works off the battery just fine. Since the unit is our only Internet connection, we have it powered up all day so it seemed to make more sense to just leave it connected to the power source. The unit is turned off at night, but usually not disconnected from the power supply. That is what we did with our original unit and it seemed to be OK.
Alan.Brandt,
SarahO_VZW
