I have a 40GB plan for our phones, ipad and the hotspot. Within one week of the new billing period, I had a notice that my data was up. I assumed this was from one of the phones that has only 2GB allowed per family base. I was shocked to check and find out that it was my hotspot that had used 56GB+ in only ONE WEEK!!! The normal use is 10GB and high had been 15 during unusual circumstances. I tried calling but finally had to use chat to discuss with Verizon. I'm told I won't have to pay for the overage, but meanwhile my account is under the "protect" which is restricting the data for all of my devices to a snail's pace. It is taking forever to get my email, and I cannot work from home under these conditions. Basically, I am held captive because of their mistake! I/m paying hundreds of dollars and can't use anything but voice and text right now for another 2.5 weeks. I'm over it and ready to change carriers. Has anyone else had this problem? I need my fair share of data that I pay for.
Have you looked at the data counters on the devices that connect to your mobile hotspot. Each of my computers use at least 25GB a month just browsing the internet on my home fiber connection. Have you set up the connected devices so that they know they are connected to a mobile hotspot instead of unmetered Wi-Fi?
On Windows 8 through 10 you can set the hotspot as metered connection.
Here is an example for connected android devices.
Can you use the Family Base subscription to restrict the amount of data allowed on the hotspot as well?
Usually when you see this, a PC is doing updating and can download large update files over a rather short period of time. There are certainly other causes. The setting of the wifi connection to a metered connection is an excellent idea by Joey2007ua_64
yes, I have never needed it though. This was totally something wrong within the system. I will make sure it can't happen again, following the great suggestions on this forum but it isn't helping me now.
thank you for your suggestions!
There was a Windows 10 update recently so it wouldn't surprise me if that was the major usage reason.
Unless the hotspot is your only option for Internet access at home, the Jetpack and mifi devices are not designed for 24/7 Internet service. If you work from home, you should look at a landline based Internet service.
