Why is my home wireless phone lights off?
truckrocket
My home wireless phone stopped working. All lights are off.
Correct Answers
Re: home wireless phone
truckrocket
Thanks for your help. It is my mother-in-laws phone and i am 900 miles away. Some how it got plugged into a switched outlet and was running on battery when the switch was turned off. All is well. Thanks, Rock
John_Getzke
Leader
Leader
No lights suggests a power failure.  Check the power connections and try another wall outlet.  If you cannot get the device to power on then contact VZW for warranty replacement or upgrade options.
truckrocket
