Why is my upload speed double my download speed?
PAPERHARBORCO
Just got the cantenna and router/modem installed today.  In the first hour I had 11/11 (down/up mbps)  After that the download speed dropped to about half , but the upload is almost double the down.  Any help?  I need 10mbps for work, which  I had for a total of an hour. Smiley Sad
This is a wired connection to the router, wired to cantenna.
Tags (3)
Correct Answers
Re: Why is my upload speed double my download speed?
John_Getzke
Leader
Leader
Restart your VZW devices.  Performance problems like the one you mentioned could be temporary.  A reboot of the systems should resolve anything that is easily fixable.  This will force them to reconnect to the towers they are aiming towards and reestablish a good connection if one is available.
John_Getzke
Leader
Leader
PAPERHARBORCO
I restarted the modem, and that helped quite a bit.  It's much faster.
If this happens again should I also restart the cantenna?  I'm not sure how to do that though.
And Thank You!
John_Getzke
Leader
Leader
Its up to you but its likely the modem device will have more of an impact than the cantenna itself.  I would not physically adjust or move the cantenna at all.  This should have been carefully adjusted by a tech when they setup the service for you.  All you would want to do is remove the power to anything for a few moments and then plug it back in.  I cannot recall if the cantenna itself has any kind of a power connection or not.
