Wireless printer won't connect to 4G LTE Orbic hotspot
niece555
Hi,
My HP Deskjet 2636 won't connect wirelessly to my 4G LTE Orbic Hotspot. I've followed the instructions for setting it up correctly and it WILL NOT CONNECT WIRELESSLY. Can someone please help me figure out what the issue is? I really need this connected for work.
Thanks
Tags (1)
Re: Wireless printer won't connect to 4G LTE Orbic hotspot
This is concerning to hear, let's take a look into this. Please send us a Private Note. *Gen
cks4301
Did support "look into this"? I have the same issue with my Brother MFC7860DW not working with my Dell G3.
cks4301, we have come across reports of similar connection issues with printers, Smart TV, etc. We would check if the Jetpack is working normally with most devices. The Jetpack not working with one device would indicate an issue with the device/printer that you are trying to connect to. In those cases, we recommend checking with the manufacture of the printer for compatibility. We hope this information helps.
-David
