citrix receiver vdi connection fails using 4620le - Citrix Status Code 1110
Dutch65
Subject line tells the story. I have tried factory reset. This is when I try to set up a VPN connection using the 4620LE.. Looked at settings via the admin console. Nothing jumped out at me... port config etc.
Tags (1)
Re: citrix receiver vdi connection fails using 4620le - Citrix Status Code 1110
7e18n1
Sr. Member
Did you see this thread?
