tab 4 8.0 wifi problem.
mneff143
I have a Verizon tab 4 8.0..I recently closed my account and still have the tab. It will not let me use the wifi to connect to anything, very frustrating!  Please tell me it is not locked some how to only work with Verizon 4g
Correct Answers
Re: tab 4 8.0 wifi problem.
Hello mneff143!
Help is here with Verizon tablet. When closing your account, you cannot use 4G on our network as the line has ended. But, you should be able to make a WiFi connection anywhere with the tablet. We are not prevening this at all. Any device can connect to WiFi. In settings, ensure your WiFi is turned on. Try other WiFi connections to see if it's just one WiFi connection you're having trouble with. Thank you for posting and have a great night!
LauraD_VZW
Follow us on TWITTER @VZWSupport If my response answered your question please click the _Correct Answer_ button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!!
MiiHere
Leader
Have you tried to forget the network and then add it back?
Hello mneff143!
LauraD_VZW
