I mistakenly changed the APN on my tablet and have tried hard reset and factory reset with no luck. How can I find the original APN to correct this issue?
Hi sunshineG5!
I'm eager to help you! Let's check this out.....please provide me with the software version of your device. You are able to locate it by following these steps:
http://vz.to/1C9mf7I
Thanks,
ChristinaB_VZW
