The beginning of December, I obtained an Ellipsis 10. I noticed that it had a slot for a microSD.
I happened to have a 16GB microSD available, so I put it in.
I found that when I used it I often had odd problems, like it shutting down by itself, being unable to turn on, not responding to touch screen, etc. I was not sure if the problem was with the microSD until I removed it, and then it seemed to work just fine.
Before I go out and buy a new microSD card, assuming the one I have is defective, has anyone had any problems using a microSD card with an Ellipsis 10?
That is definitely an odd situation, but we are here to solve this mystery! Where did you obtain the SD card from?
NicholeK_VZW
