I purchased the Motorola Edge Plus in July, 2020. After using the phone for approximately 5 hours yesterday, a dark shadow of greyish-black spots appeared along the left side of the display. Most of these spots disappeared after the device cooled down, but a small area of lighter shadow remains. Is there a fix for this?
mrescudder, I am sorry to hear you are experiencing issues with your phone. I know how important it is to you. No worries, help is here. Just to clarify, did you use the phone for 5 hours non-stop?
DiaS_VZW
It is important that your device works. When the shadows were on the screen, was the device noticeably hot to the touch? Did restarting it make any difference?
PeterP_VZW
Restarting doesn't resolve the issue all the way. The phone is warm but not hot after about 15 minutes of use my phone starts to have a green tint and purple spots that just get worse over time.
I've had the same issues within a few weeks of having the phone. Verizon has been zero help and have said there is no warranty, which is a lie (there is a one year warranty on phones they sell). A couple of reps actually told me to file a fraudulent insurance claim on an undamaged phone! Verizon customer and product service has been in a steady decline for a number of years. My best advice would be consider another carrier as soon as you can.
We certainly want to ensure you have a properly functioning device, screen and all! We are happy to help you here to get that resolved. Are you still experiencing issues with your screen?
I have the same issue with my phone and it is very difficult to use,sometimes impossible as the coloring spreads and darkens over time.
The Motorola devices do have a manual light control and they dim when not in use. Try taking a look at your options and if you're still having issues with the darkening, please Private Message us for live agent support. - NicholasS_VZW
what does the length of time the device gets used for have anything to do with a poor design? that is the most ridiculous question i have ever heard. motorola, rather lenovo, is aware of the issue and is choosing to do NOTHING about it. meanwhile verizon only see's dollars and payments and continues to sell a KNOWN defective device.
my device is doing the same thing as of today. i will be doing a warranty claim soon. and it will not be another lenovo device.
