Motorola Moto g7 Power missing battery indicator widget after Android 10 update
toddsdonald1
Has anyone figured out how to get the circular battery indicator widget back on their phone after the Android 10 update? There's still the circle widget but the battery indicator is gone. The only battery indicator I can see now is the itty bitty teeny weeny one in the upper right.
