Phone will not go above 3G. HELP?
Elphaba719
I have looked up how to get my phone to go to LTE and I followed what it said and changed my phone to LTE/CDMA but it still hasn't changed to 4G LTE. Please help. It has been stuck on 3G for 3 weeks and it makes everything so much slower and sometimes I can't even access the internet. Please help.
Re: Phone will not go above 3G. HELP?
Ann154
Expert
Expert
Which phone model do you have? What is the zip code of your location?
bearone21
Leader
when i changed it was advised to remove the sim card, reinstall & reboot.
Elphaba719
I have a Galaxy S6 edge. And my zip is 92866
Elphaba719
Okay I will try that.
