S7 Edge to IPhone 12 Pro Max/Move to IOS does not work/What now?
Tobystan2000
I am moving from Samsung Galaxy S7 Edge to IPhone 12 Pro Max.  In order to migrate data from Android to IOS, it is recommended to download and use the MOVE to IOS application.  For some reason, my S7 Edge continually disconnects from WiFi.  I have tried all of the fixes found on YouTube to no avail.
What is my next step?
Please help!
Thank you!
Re: S7 Edge to IPhone 12 Pro Max/Move to IOS does not work/What now?
Tobystan2000, we would be happy to help with getting the content transferred from your Android to your new Apple device. You can use the following link to be able to start with this process:
https://www.verizon.com/support/knowledge-base-212880/
Please let us know if this helps!
