I have a samsung galaxy j3v. When charging the battery should I get a signal when the battery is fully charged?
in settings/battery/options you may get to make that choice.
thank you very much
Marv
Knowing when your phone is charged up and ready to go is important, AMADEUS3345.I have had phones in the past that have beeped when fully charged, but each phone is different. When you have the phone plugged in do you see a charging indicator on the display? Have you received a notification about a full charge before?
JosephE_VZW
