Will Ellipsis connect to CDMA (3G) if LTE (4G) is unavailable? If yes, can you manually force the tablet to run on CDMA?
Cat007
Correct Answers
Re: Will Ellipsis connect to CDMA (3G) if LTE (4G) is unavailable?  If yes, can you manually force the tablet to run on CDMA?
chris1060
Sr. Member
The Ellipsis 10 only operates on WiFi and the 4GLTE network. It dues not utilize the 3G network.
Ann154
Expert
Expert
Which Ellipsis tablet model do you have?
In checking the specs on the Ellipsis 7 and the Ellipsis 8, the tablets only support 4G LTE with no fall back to the 3G EDVO network.
Cat007
Ellipsis 10.  My apologies for not mentioning that.
chris1060
Sr. Member
Cat007
Thanks.
chris1060
Sr. Member
You're most welcome.
