Battery Drain
ray14c
How do I make my Samsung Intensity III phone hibernate?? Mine will go to the black screen at times, but stays on the home screen most of the time, which drains the battery.
Re: Battery Drain
Hi ray14c,
We want to make sure your battery works to the maximum. I recommend looking over the display settings to get your device in the lowest modes to save on battery life. To check out options visit http://bit.ly/SfFWGR. Let us know if you have additional questions.
Thank you,
MariaC_VZW
