I'm sorry but i just saw my fathers way of charging his phone and it is by sticking a large object while the phone is plugged in at a 45% angle. I know i had the one (forget the name, but opened with full keyboard underneath) and had same problem. is there an easy fix? i feel like you should be able to tighten with small pliers.... the metal bracket around where the phone gets plugged in or something.
I'm not sure what's happening here, DCUSA. Is the charging port on the phone broken or loose? Or is the connector piece not working correctly? I know the connectors are sometimes very small and delicate and care needs to be taken when plugging and unplugging; still I have not had an issue with the many phones we have had over the years.
Does the phone charge fully and normally with whatever setup your father has?
