LG Extravert appears to charge but doesn’t power on.
When connected to charger Verizon logo appears and then the screen displays indicates that the battery is charging. After several minutes display will read that battery is fully charged and to please remove from charger to save energy.
However when removed from charger phone screen goes black and phone is unresponsive; pressing the power button does not turn on the phone.
Phoned will not turn on when still on the charger either.
I have removed the battery and reinstalled it, as well as leaving it out for an extended period.
As suggested in manual, I have tried pressing and holding the PWR/End Key for 8 seconds to reset the phone.
I have cleaned the charger and battery contacts.
It is an original LG charger.
It is an original LG battery.
It is an original LG USB cord.
Anyone have a similar issue?
Any suggestions for something I might have missed?
Any undocumented tricks to reset or power on?
Update:
Phone turned on today.
Not sure why it is ok now, or what issues was before.
