LG Revere 3 Bluetooth input problem
CGXINC
I recently switched to Verizon and opted for the LG Revere 3 phone, which I immediately paired to my Ford Sync system.  Steering wheel activation buttons and voice commands work great, but I am unable to enter my passcode from the numeric keypad on the dash when checking voicemail messages.  I never had this problem with the last two phones I paired to this bluetooth system in the past.  Any suggestions?
Tags (1)
Correct Answers
Re: LG Revere 3 Bluetooth input problem
CGXINC
There was a software update available on March 21st that fixed the problem - everything works properly now.
Thanks
dilbertaz
Sr. Member
When you first paired did it ask for additional permissions?  If it did you you answered No and remember was set it will never ask again unless you delete the paired device and add it again.  Just a thought.
CGXINC
Thanks
