Solution for very low volume on bluetooth for Samsung Intensity III?
rhinoceros
I just got a Samsung Intensity III. When I use my Motorola bluetooth device, the volume is so low that you almost cannot hear it. The device worked fine with my previous phone. Is there a way to increase the volume or some other solution? I have the phone master volume turned all the way up.
Thanks.
Re: Solution for very low volume on bluetooth for Samsung Intensity III?
Rhinoceros, most bluetooth devices give you the option of adjusting the volume directly on the earpiece. Perhaps removing that device from the bluetooth settings on your device and then resyncing it again will resolve that issue. For more device support, click http://bit.ly/yN1P80 ^LH
