When I enable WiFi and connect on my LG Exalt LTE does it actually use WiFi for phone calls?
denmarks
Does it use whatever signal is stronger or will it always use WiFi if connected? Is there a way to actually tell what was used if the best signal is used?
Re: When I enable WiFi and connect on my LG Exalt LTE does it actually use WiFi for phone calls?
boringusername
Sr. Member
On smartphones there is usually an indicator that tells you if it's wi-fi calling or not. If it works like most Verizon phones you basically have to have no signal before wi-fi calling kicks in unless you turn off mobile data
denmarks
This is not a smart phone. It is the only Verizon LTE flip phone. There are 2 signal strength indicators, one for WiFi and the other for cell. There are little up and down arrows that I assume indicate data moving up and down. Since the phone is to my ear I do not see the screen during a call. When I look at the arrows when not making a call they periodically flash up or down.
tikibar1
MVP MVP
MVP
From page 73 of the user manual:
Activate Wi-Fi Calling 1. From the Call settings menu screen, press the 1 key Activate Wi-Fi calling to allow you to make calls using Wi-Fi when the mobile network is not available.
https://ss7.vzw.com/is/content/VerizonWireless/Devices/LG/LG%20Exalt%20LTE/verizon-lg-exalt-lte-ug-e...
boringusername
Sr. Member
I didn't say it was a smartphone. I know it's basic phone. No offense, but please try READING what I wrote.
denmarks
Thanks everyone. I finally found the setting. I had WiFi connected but did not have WiFi calling turned on. It seems that WiFi calling would only be used if the cell signal was not available. Since I have a good cell signal in the house there seems to be no need for WiFi so I turned off the WiFi connection.
denmarks
I wanted to add another sentence but get an unexpected error when clicking actions.
With WiFi off I probably have a longer battery charge.
boringusername
Sr. Member
Yes turning wi-fi off if you're not using should save battery. Also if you did want to wi-fi calling even with a good cell signal you could put the phone in airplane mode then turn on wi-fi
