phone problems
jtroutt748
why does my phone shut off when i go to send a forward or any other kind of message
Correct Answers
Re: phone problems
jennifer this is a mystery to us too! I'm on the case. I just need to ask you a few questions. Which phone do you have? Is there any physical or liquid damage?
I recommend that you uninstall any unwanted applications that you've downloaded, delete any unwanted text messages, e-mails and call logs. Once you have cleaned your device out, you will need to power it off/on and test the text messaging feature. Keep us posted.
LasinaH_VZW
>Personal info deleted<
Message was edited by: Verizon Moderator><
Re: phone problems
ttipgem
Sr. Member
What phone?
Re: phone problems
LasinaH_VZW
