Curve Battery Power?
ihaynes
I just got a curve yesterday and did not charge it sufficiently. It now wont turn on, but when plugged in shows a faint green blinking light. How long does it take before it is functional again?
BBgirl09
Contributor - Level 1
It might take a few hours to charge it fully if the battery was completely discharged.  Also when the battery is fully discharged, you need to use the wall charger and not the USB charger with your PC.  BlackBerry batteries like to be kept charged up or "topped off", they shouldn't be fullly discharged before charging (like what was recommended in the past).
XtremeBerry
Contributor - Level 3
I charge my curve every day. With lithium batteries there is no "memory" issues to speak of so charge them as often as you like unlike the Nickel-Cad batterys of days gone by.
