Blackberry Battery Problem
workingman
Contributor - Level 1
My phone kept on restarting after i put in one of my batteries, Could it be doing this because the battery has gone bad?
1 Reply
Android10
Contributor - Level 3
It is possible the battery is not functioning correctly. Make sure the battery is in the device correctly.  Then ensure that the battery is fully charged.  If the problem persist, I would recommend taking the phone, charger and batteries to a store location to have a technician take a look at them.
