I noticed a gap between the top of the tool belt and screen which lets light bleed through in spots when the keyboard back light is on. Does anyone else have this issue? I'm wondering if I should get an exchange since I'm still within my 14 day return period. Everything else on the device looks and works perfectly, so I'm not sure if it's worth the risk of getting another device that might end up having more of an issue than this current one.
DigitalCreation, having a properly working device is paramount. I welcome the opportunity to assist you with your inquiry. If something is looking awry on your device, I’d definitely return it to the original place of purchase and compare it with another device of the same make/model to see if that is the normal behavior. It’s always best to take the necessary precautions to ensure your device’s longevity.
EbonyR_VZW
EbonyR_VZW
