Need help with USB charging of Blackberry Pearl
tcjack
I have a Pearl, 8130.  When I plug it into my computer, via the USB port and cable, a box pops up on the Pearl that  says
USB charging current is not sufficient.  Verify that you handheld is connected to a powered USB charging source and that the proper USB driver is installed.
I believe the USB port on my laptop is fine.  How do I check the driver install?
Tags (3)
Re: Need help with USB charging of Blackberry Pearl
TheGreatOne
Sr. Member
I did a search,but don't know which one you want to install. Check out the link below though:
http://search.vzw.com/?q=USB+Driver+install&ss=clc&p=3296&x=0&y=0
