I have an odd problem. Actually, 2 of them. First, it intermittently will stop "previewing" ringtones when I'm setting profile options. It migth do it for a few of them, then it just stops. I can select one, and it will behave correctly function-wise, but it's weird. A reboot usually fixes this. But it gets old.
Second is the led, which I've grown accustomed to blinking when I get emails or messages. That's how I know I had something when I return to my desk. Now all of a sudden, it doesn't seem to be working long enough. It begins blinking like it should, then just stops after some period of time.
I thought I'd be smart and reload os 4.5.0.175, but after I got it all back up and running and reconfigured, it's still doing it.
Is there some settings that I'm missing somewhere?
Thanks!
Dan
"Is there some settings that I'm missing somewhere?"
Dan I use BerryBuzz.You can set different colors and lenth of time for color to blink. Quite inexpensive. Get it at crackberry dot com .
" Dan I use BerryBuzz.You can set different colors and lenth of time for color to blink. Quite inexpensive. Get it at crackberry dot com ."
Thanks for that info, but
1) it's a problem that I'm trying to solve where it WAS doing okay and then stopped doing okay, and
2) doesn't address the ringtone problem.
An add-on app to control it, while I'm sure it works just fine, isn't really a solution.
One added really quirky note: it all of a sudden seems to be working more or less better now. I didn't do anything. The gremlin must have gotten scared off, lol. I expect it will be back, though, and I'm just waiting for it.
