When you open Visual Voicemail the LED coverage indicator goes out for good until you reboot. When you get a notification after using Visual Voicemail you only get your sounds, and the LED doesnt work... All is well once you reboot the device. That is until you open Visual Voicemail again. Reinstalled the app several times, always does the same thing.
I think VVM needs an update...
