MiFi2200 / VPN / Remote Desktop Problem
CSM2010
I'm having a problem using Remote Desktop Connection over VPN for a particular client I work for. For everyone else it works fine. I connect to the internet, launch VPN, and use RDP to connect to a machine. However, for this one customer I can get the VPN to work fine, but as soon as I try to connect to a remote computer I get kicked out within a minute or so. I've debugged it and it is definitely something with the MiFi2200 since I can connect and function otherwise. The error I get references the Security Gateway and the termination appears to be from my side and not from the customer's side. If anyone has had a similar issue please let me know.
