Droid mini charging problem
vtvirga
Droid mini powers on when plugged in to charge, then immediately powers down.  It does this repeatedly when plugged in to charge, and never did it before.  How do I correct this behavior?
Customer Service Rep
That certainly is some strange behavior, vtvirga. Did you notice that trouble start after a particular application was installed or the phone updated? Are you still using the original home charger that came with your phone? We'll figure out this mystery.
JenniferH_VZW
Follow us on Twitter www.twitter.com/vzwsupport
vtvirga
I took the back off, put a small amount of outward pressure on the power button and cleaned it out with some air. It hasn't done it again since, so I imagine the power button may have been sticking.
Thanks.
vtvirga,
Thank you for doing that. What is the software version? You can find this in Settings>About Phone. Are you using the charger provided by the manufacturer? Is there any damage to the device?
AdaS_VZW
Follow us on Twitter at @VZWSupport
