HELP!!! I NEED HELP WITH MY PHONE!!
I HAVE THE MOTOROLA DROID, AND IT IS FROZEN. I TOOK THE BATTERY OUT AND EVEN THE SD CARD, BUT ITS NOT WORKING IT SAYS:
BOOTLOADER
2C.7C
OK TO PROGRAM
BATTERY OK
TRANSFER MODE:
USB
ANYONE KNOW WHAT i HAVE TO DO TO FIX IT, PLEEEEASE????
1 Reply
Not applicable
07-01-2011
09:44 PM
MARIAH,
Hello! What you can do, if the phone is still not working, is an alternative reset. Alternative reset steps are here. You will want to make sure you have all your personal info backed up to Gmail or SD card before doing the reset as it will place the phone back to the factory default settings. Once the reset is complete the phone will reboot and you will begin the activation and set-up process.
Have a great day!
