Possible Solution To Syncing Problem
TaeSong
Contributor - Level 1
If you're having problems with syncing email / data take a look at Power Control widget.
Wi-Fi, Bluetooth, Location (GPS), Synchronization, and also adjust Display brightness
The second button on the right is the toggle for data sync.
